DEVELOPERS FORUM - Download Files
gaoyuanhe - Sunday, November 14, 2010 9:41 PM:
hi,
I write a method trying to download files from the document,but when the document contains more then one file,it willl show an error message,
Failed to download the file 'a.xls' into C:
The first flie has been downloaded.
Code is as follows :
function downloadFile(docId)
   //Search by docId
 var fileItems=innovator.newItem("document file","get");
 fileItems.setProperty("source_id", docId);
 fileItems.setAttribute("where", "related_id is not null");
 fileItems = fileItems.apply();
 if(fileItems.getItemCount()<1) {return;}
 for(var n=0;n<fileItems.getItemCount();n++)
  var fileItem = innovator.getItemById("File",fileItems.getItemByIndex(n).getID());
  if (fileItem.isError()) {
  top.aras.AlertError("File Not Found: " +fileItem.getErrorDetail());
  return;
  var fileName=fileItem.getProperty("filename");
  // Get the URL to the file and download it
  var fileURL = top.aras.getFileURLEx(fileItem.node);
  var results = top.aras.vault.downloadFile(fileURL);
  if (!results) {
  top.aras.AlertError("Unable to retrieve the file ("+fileName+") from the vault");
  return;
Someting wrong?
Thanks in advance.
